the back light are not working the fuse and lights aew good, can not find the switch were is the switch?
Nov 12, 2009 at 9:48 PM
SAE1080
MEMBER
THe backup switch is a chintzy unit that is threaded into the MTX75 transaxle. You have to remove the battery, tray and then the aircleaner bits and then support the transaxle with a jack and remove the transaxle/motor mount to expose the shift linkages that is on the upper horizontal surface of the gearbox case. (Yes, I had the SAME problem in my 2005.)
