2005 Ford Focus Refueling problem
2005 FORD FOCUS
50,000 MILES • 6 CYL • FWD • MANUAL
FOCUSDRIVER
Refueling when gas gauge shows 1/4 tank. Gas pump shuts off after a small amount of gas, $1 or so at a time. Happens at different gas stations. I tried inserting the gas pump nozzle in different positions. The same result. Any ideas?
Oct 15, 2009 at 3:11 PM
RAPTORSTX
I have the same issue with a Ford Focus ZX4 ST. I just rolled 50k and with whatever amount of gas in the tank, the pump shuts off after only about 1-10 seconds of pumping gas. It sounds as if the gas is having difficulty flowing into the tank due to a restriction somewhere. Most gas pumps shut off when gas reaches the nozzle during pumping. Changing the position of the pump handle has no effect, but it appears changing the rate of gas being pumped does. While exerting minimal pressure on the pump handle, a lower volume of gas is pumped over time which seems to alleviate the problem temporarily. Maintaining a low, fixed pressure is very difficult though.
Dec 16, 2010 at 12:45 AM
For fuel to enter the tank, air must exit. THere is a vent that allows this to happen. I believe on your year it runs along the filler tube and vents into the atmosphere when the cap is open. Check to see if it is dammaged or plugged.
Let me know what you find.
Dec 17, 2010 at 4:48 PM
