usually a 30mm
Remove or disconnect the following:
Rear wheel
Wheel speed sensor, if equipped
Brake drum, bearing and spindle assembly.
To install:
Install or connect the following:
Brake drum, bearing and spindle assembly. Tighten the bolts to 49 ft. lbs. (66 Nm).
Rear wheel
Mar 15, 2021 at 7:41 PM
