Electrical problem
2005 Ford Focus 4 cyl Front Wheel Drive Manual 100k miles
I have a 2005 ford focus. In the past several months I have had the battery and the alternator replaced. The car seems to have a bad ground somewhere. There are times when you will go to start and have no power. Sometimes while driving you wil hear a clicking sound under the dash and the headlights will flicker. If you change to high beams there will be no lights. Anytime the clicking sound appears the car will have no power once the ignition is turned off. Jump starting will get the car started back up 100% of the time. The problem is intermittent. Is this a bad ground from when the alternator was installed? could it be an ignition switch?
Dec 29, 2009 at 2:23 PM
