It just unbolts. Unplug the wiring harness, and have the parts store recommend a good cleaner they have for it. I will say that usually, when they go bad, they are bad. Here are directions for checking it.
Let me know if it helps.
The Idle Air Control (IAC) valve is used to control idle speed. The amount of air allowed to bypass the throttle plate is determined by the PCM.
When the engine is cold, air flows through the valve during all modes of engine operation to maintain the factory set idle speed.
Testing
1.8L Engines
Fig. Typical IAC valve wiring schematic and connector terminal identification-1.8L engines
1.Turn the ignition key OFF.
2.Connect jumper wires from the sensor connector to the wiring harness. This permits the engine to operate normally while you check the sensor.
3.Connect a Digital Volt Ohmmeter (DVOM), set to read resistance, between sensor terminal SIG and the negative battery cable.
4.The resistance should not be greater than 10,000 ohms.
5.Connect the DVOM, set to read resistance, between sensor terminal VPWR and the negative battery cable.
6.The resistance should not be greater than 10,000 ohms.
7.Turn the ignition key ON.
8.Connect the DVOM, set to read voltage, between sensor terminal VPWR and the negative battery cable.
9.The voltage should be more than 1 volt.
10.Connect the DVOM, set to read voltage, between sensor terminal SIG and the negative battery cable.
11.The voltage should be more than 1 volt.
12.If the readings are not within specifications, replace the IAC valve.
1.9L And 2.0L Engines
Fig. IAC valve (solenoid) connector terminal locations-1.9L and 2.0L engines
2.Unplug the sensor electrical connection.
3.Due to the diode in the IAC valve, be sure to observe the correct polarity when connecting the DVOM.
4.Connect a Digital Volt Ohmmeter (DVOM), set to read resistance, between the sensor terminals as follows. Connect the positive lead to the VPWR terminal and the negative lead to the IAC terminal.
5.The resistance should be between 6 and 13 ohms.
6.Measure the resistance between either of the valve terminals and the valve body. The resistance should be greater than 10,000 ohms.
7.If the resistances are not within specification, replace the sensor.
Fig. Connect the DVOM positive lead to the VPWR terminal and the negative lead to the IAC terminal. The resistance should be between 6 and 13 ohms
Fig. Measure resistance between either of the valve terminals and the valve body. The resistance should be greater than 10,000 ohms
Jul 16, 2010 at 11:49 PM
