2004 Ford Focus cruise control and back up lights
2004 FORD FOCUS
92,000 MILES • 4 CYL • FWD • MANUAL
WEEZER1489
  • 4 POSTS
i have a 2004 focus and the cruise control and back up lights both stopped working. and the fuse that they are on keeps popping and i dont know why. what do you think the problem could be?
Feb 22, 2010 at 1:48 PM
BLUELIGHTNIN6
  • 16,542 POSTS
suspect faulty clutch pedal position switch
Feb 22, 2010 at 1:52 PM
WEEZER1489
  • 4 POSTS
would that cause the fuse to keep popping though?
Feb 22, 2010 at 2:00 PM
BLUELIGHTNIN6
  • 16,542 POSTS
if fuse is blowing then it indicates a fault in that circuit. the CPP switch controls both the back-up lamps as well as part of the CC system. if the switch is bad or the wiring to the switch is bad then it will continue to blow the fuse until the issue is fixed.
Feb 22, 2010 at 2:04 PM
WEEZER1489
  • 4 POSTS
okay thanks. well we put a new fuse in it and the cruise works now but still no back up lights.
Feb 22, 2010 at 3:52 PM
BLUELIGHTNIN6
  • 16,542 POSTS
definitely points to faulty CPP switch, just make sure the wiring is not damaged and is connected good at the switch first
Feb 22, 2010 at 3:55 PM
WEEZER1489
  • 4 POSTS
sweet thanks a lot well take a look at it now and hope it fixes it.
Feb 22, 2010 at 4:02 PM
