2003 Ford Focus Struts
2003 FORD FOCUS
MSTWANA
Noises problem
2003 Ford Focus 60,000 miles
How do you do know when struts need to be replaced?
Mar 16, 2009 at 7:32 AM
Perform the bounce test
Before you visually inspect the suspension, do a simple bounce test to tell if the shocks or struts are weak. A bounce test is not a very scientific test because it requires a certain amount of judgment. Worn shock absorbers and struts that allow more than one or two gyrations after rocking the bumper up and down and letting go have reached the end of the road and should be replaced. But what about the "marginal" dampers that still soak up some of the bounce, but not as well as new ones? They should probably be replaced, too, to restore like-new handling and ride control.
Mar 16, 2009 at 7:42 AM
