2003 Ford Focus I lose heat
2003 FORD FOCUS
122,000 MILES • 4 CYL • FWD • AUTOMATIC
RICHMICHAELS
why do I lose heat when I get to a red light or slow down in traffic? I seem to get heat while i've been driving for a while, but like I said, it slowly cools down while I come to a stop. The Fan works no problem, I'm getting air into the car, but it's not HOT air... Can anyone tell me WHAT's going on and how I can fix it??
also, my heated seat sees to have stopped working. I checked the fuse underneath the steering column and it looks just fine. Could these two "eat" issues be related??
Any help is greatly appreciated
Cheers,
M.R
Feb 25, 2009 at 10:36 PM
Check the thermostat and also the heater core if its clogging up also if it has a heater control valve-if not could be an air mix/blend/mode doors and vacuum/actuator problems and HVAC control module
Its two different problems.
Feb 26, 2009 at 1:50 AM
JKIRKERX
My heater just started doing the same thing. When the fluid is low, there's not enough to make it into the heat exchange inside the car. I added 1/2 a gallon, and it worked fine, but there is leak somewhere, hope it's not a bad heater core.
Feb 28, 2009 at 11:59 PM
