2002 Ford Focus 2002 Ford Focus SOHC Engine Knock
2002 FORD FOCUS
94,000 MILES • 4 CYL • FWD • AUTOMATIC
VALKYRIE
  • 4 POSTS
I am getting a rather loud engine knock. It sounds like it is coming from the top end of the motor. Has there been a problem with the Focus that may cause this? Where should I begin to look? I changed the spark plugs and wires. No. 4 plug was a little wet. No. 1,2,3 looked okay.
Apr 3, 2009 at 7:53 AM
BLACKOP555
  • 10,386 POSTS
4 was wet with what? oil? gas?
have you checked your oil level?
Apr 5, 2009 at 9:01 AM
VALKYRIE
  • 4 POSTS
No. 4 plug appeared to be wet (damp) with gas. I had just changed the oil about a week prior to this and the oil level is good.
Apr 6, 2009 at 8:06 AM
BLACKOP555
  • 10,386 POSTS
disconnect knock sensor and see if problem gets better or worsens.
any check engine light?
Apr 6, 2009 at 6:58 PM
VALKYRIE
  • 4 POSTS
The check engine light did come on. No. 2 & No. 3 cylinders are misfiring. I did check and change the timing belt and tensioner but this didn't change anything. No. 2 & 3 plugs are wet (appears to be oil). I was able to drive it slowly to a repair shop so they can help me diagnose the problem.
Apr 7, 2009 at 4:39 AM
BLACKOP555
  • 10,386 POSTS
let me know if you want to check up on their prices and diagnostics to let you know if its a good word!
Apr 7, 2009 at 6:30 PM
VALKYRIE
  • 4 POSTS
The diagnostic test revealed that there is no compression on No. 3. I was told there is probably a seat/seal on one of the valves that may have become dislodged. I am going to pull the head and take it to a machine shop. I was given a price of $325-350 to have the head rebuilt.
Apr 8, 2009 at 5:28 AM
BLACKOP555
  • 10,386 POSTS
that is a very very good price to have the heads rebuilt.
there is nothing wrong with that and that is a possibility for your problem. did a wet and dry compression test get performed on that cylinder?
Apr 8, 2009 at 1:44 PM
