2001 Ford Focus Strong vibration at start up, worsens when
2001 FORD FOCUS
GALILEOFIGARO
Suspension problem
2001 Ford Focus 4 cyl Two Wheel Drive Automatic 138k miles
There's a strong vibration at start up and worsens when accelerating. You can feel it all over the console, rear view mirror, even pedals. I had exact same issue 5 months ago and was resolved changing all 3 engine mounts original from Ford.
Also I just changed ignition coil, cleaned idle control valve 6 months ago, changed spark plug wires 4 months ago, changed EGR tube too, vacuum hoses are ok.
Please help and thanks in advance.
Jun 24, 2010 at 11:47 AM
Is the check engine light on? Does it run good off an idle? Have you checked the catalytic converter to make sure it isn't plugging? Fuel pressure checked?
Jul 3, 2010 at 3:00 PM
GALILEOFIGARO
Unbelievable, original Ford engine mount was defective with fluid all over the place. Changed at Ford dealer with the apologies of the guys at parts.
Jul 14, 2010 at 7:22 PM
That will do it. I'm glad you got it fixed. Let us know if you have other questions in the future.
Jul 16, 2010 at 11:44 PM
