2001 Ford Focus Speed Ratings
2001 FORD FOCUS
TENORBACH
Tires and Wheels problem
2001 Ford Focus 4 cyl Automatic 115000 miles
I am doing research for a set of replacement tires. Ford's tire specifications for my car are P195/60R15 87T. On the tire label affixed on the rear driver side door jamb, it states that replacement tires MUST be with an equivalent speed rating of "T". Looking at the different brands such as Goodyear, Michelin, BF Goodrich and so on, most have online tire selection tools where you can enter in the Make, Model,Year and Option (such as SE or ZTS for a Ford Focus) of your vehicle and they will give you a list of their recommended tires for your vehicle. Some of the tires have 87T load/speed codes, while others have codes representing higher speed and load support. Most of the tire manufacturers have said they recommend replacement tires with an equivalent speed rating or higher, while Ford's specification label only says an equivalent and nothing about tires that can exceed those specifications. It has been difficult to speak to anyone at Ford about my situation. If I am limited to only 87T, then given the local businesses in my area where I can purchase tires and have them installed, I only have a few choices. But if I am able to exceed 87T, I have more options to choose from, especially when it comes to features of tires including dry & wet traction, smoothness and quietness of ride, etc.
Any help is greatly appreciated.
Feb 9, 2010 at 10:05 AM
2CARPRO JACK
  • 11,533 POSTS
Going beyond Fords recommended tire rating wont hurt anything.The main thing is to keep the size the same for thetransmission adn engine computers.If you go to bigger tires, they need to be programmed in when possible.A higher speed rating wont hurt the ride or noise level of thetires, that is the sidewall thickness that will determine most of the ride characteristics.The tread pattern will determine if the tire is going to be noisey or quiet, an aggressive tread will make more noise, whereas a standard tread pattern will be quieter.
Feb 10, 2010 at 6:51 AM
TENORBACH
Thank you for your reply. I don't have any need to change the size of the tire. I don't need a higher speed rating either. Unless I have an emergency, and even that would be a stretch, I never drive above a constant speed of 70MPH. I've only hit 80MPH passing another vehicle, usually an 18-wheeler.
But I am glad to know that I do not have limit myself to only 87T tires. Now I have a bigger selection of tires to choose from, each with varying levels of dry/wet traction and "Ride Comfort" and "Quiet Ride" as Goodyear has listed on their website and other manufacturers do as well.
I may have another follow-up question in the future, but not at the moment. Thank you for your help. I wish I could have donated more for your answer, but my budget is tight at the moment.
Feb 10, 2010 at 9:32 AM
2CARPRO JACK
  • 11,533 POSTS
No worries, glad to be of help
Feb 10, 2010 at 9:40 AM
