I own that same vehicle and if I remember right, you shouldn't have to remove any bolts to change the bulb. On those vehicles, the one bulb is both the high and low beam. There should be a round capsule like object one the back side of the headlight. It is a twist type capsule. Turn it to the left and pull and it should expose the socket assembley. The trick though, is that there is a bracket type wire that holds the socket in. It takes a little bit to figure out how to get it loose but there is a hook you have to move that wire around. Once you get it around that hook, the socket should pop right out allowing you to change the bulb. Then basically do everything in reverse to get it back in. Getting that wire type bracket around the hook is a little tricky as well but once you have done it, it is second nature. I have to change mine tomorrow. If it's not to dark I might be able to post some pictures to describe what exactlly I am talking about. Hope this helps.
Nov 13, 2007 at 9:46 PM
