Problem with cooling fan radiator fan not working?
2000 FORD FOCUS
65,000 MILES • 4 CYL • FWD • MANUAL
H MALTBY
cooling fan comes on seconds from starting from cold and then intermmitant whilst driving and temperature gauge goes to half position afew hundred yards from setting off. But there are no running problems. Is this a cause for concern? If so, what do you think will cure it - Thanks
Jun 24, 2008 at 7:02 AM
SQM
  • 6,383 POSTS
The radiator cooling fans are designed to turn on when the engine reaches the operating temperature. It also comes on when the AC is on, regardless of the engine temperature.
It will turn on and off as needed depending on the engine temperature or A/C usage.
This is standard operation of the radiator cooling fan.
So, if you are not experiencing any overheating, then odds are it is functioning normally.
Here is a helpful guide:
Thank you.
Jan 29, 2022 at 9:31 PM
