2000 Ford Focus idles high in drive mode
2000 FORD FOCUS
140,000 MILES • 4 CYL • FWD • AUTOMATIC
RARAREE
the idle rev's upto 3000 rpms while its in drive. Constantly have to keep foot on brake or it will go ahead without any acceleration. Dianogstics had 2 different codes and the mechanic said that one of the parts would be 500.00 but would not guarentee that it would solve the problem. Had the wiring fixed about 6 months ago at ford dealership. Is there anything else I can do than to take it back to dealership"\?
Feb 9, 2009 at 1:36 PM
SAWMASTER88
  • 38 POSTS
I'm not sure what part the mechanic told you would fix the problem, but I would take a serious look at the Idle Air Control Valve. I doubt that the part is that expensive, and to be honest it is something you could probably fix yourself. I would call your local auto parts store, and check the price, and maybe someone there could tell you exactly where the part is located. Hope this helps and good luck.
Feb 9, 2009 at 9:57 PM
EDIT2009
I had the same problem with my focus. Your car probably needs an idol control valve, the part is around 120 bucks. My mecanic fixed it for me for less than $200.
Mar 2, 2009 at 1:10 PM
