2000 Ford Focus California catalytic converter
2000 FORD FOCUS
82,000 MILES • 4 CYL • 2WD • MANUAL
LSIMONS8
  • 4 POSTS
recently my engine light came on so I took it into the mechanic and he said that it was a problem with my catalytic converter. The car seems to be running just fine so we tried resetting the computer to see if that would work but it didnt. the mechanic said that it looks like my car is originally from california and they have special emissions laws and therefore my car had a specialized catalytic converter. he said that he would have to order it straight from Ford because a regular one wouldnt work and it would cost me 630 dollars just for the part. I need a second opinion because I need to get my car to pass safety and emissions and I dont want to pay 800 dollars if there is a chance that a generic catalytic converter would work, which I believe run about 50-70 dollars. thanks for your help.
Mar 17, 2008 at 11:45 AM
AACPLUS
  • 60 POSTS
Depending on the State you reside, you should check with the Dept of Transportation. I know in my State, if the car is no longer registered in California, then only federal standards apply. This would include a Universal catalytic Converter in most cases. However, If the car is licensed in California even though you are no longer in their domain, the Ca. Emissions standards will apply. So, if that's the case, you are in a catch 22 if you need to pass an emissions test, unless you aquire a waiver from the DOT allowing federal standards replacement on a CA. licensed vehicle, so that it can actually pass a test and be licensed in the new State. (I am only using my State requirements as this guideline). Also, if relocating outside of the USA, you may obtain a DOT waiver to have the emissions removed if you are going to use leaded fuel outside the country.
Good luck, Check it out with your DOT.
If federal compliance is the standard, you will save a ton of cash using the more inexpensive replacement converter. (some still require duel in-line converters depending on the model and drivetrain, or a duel in whick is also expensive, but still about half of a dealer replacement.
Mar 17, 2008 at 12:07 PM
AACPLUS
  • 60 POSTS
I want to add, I hope the diagnosis is correct. Was a vacuum test or gas analysis performed? Does it smell sulfuric? Although cases such as yours do occur, (I've seen my share), it is less common than usual symptoms. .
Mar 17, 2008 at 12:13 PM
LSIMONS8
  • 4 POSTS
sorry I forgot to mention that i am now in utah. I dont believe the mechanic did either one of those test, he just plugged in his computer thing. I cant see any difference in my cars performance from now and before the engine light came on so I dont really care to get it fixed if I dont have to. the problem is just getting it good enough to pass emissions and I know that wont happen until that engine computer says ready for the catalytic converter. Two guys that I have talked to here say that unless I get the exact replacement converter then that engine light wont go off and I am screwed. I hope that they are wrong though.
Mar 17, 2008 at 1:25 PM
LSIMONS8
  • 4 POSTS
it doesnt smell at all
Mar 17, 2008 at 1:28 PM
