the problem first started the battery light came on?
1920 FORD FOCUS
MATT41178
  • 31 POSTS
I have a 2000 ford focus manual trans 2.0 DOHC 100,000 MILES , the problem first started the battery light came on when the car was at crusing speeds but when accellerating it would go off, I had the battery tested at autozone and they said the battery was bad so I reaplaced the battery and still had the same prblem then I had it tested again at autozone and they said the alternator was putting out too much power and over charging the battery so I changed the alternator and every thing was good bor about four months eccept the battery light stayed on all the time, two days ago the car was just dead I charged the battery but it still discharges I have the old alternator and took it to be tested and was told it was still good.
please help with this I hate this car
Thanks
May 25, 2007 at 11:07 AM
MATT41178
  • 31 POSTS
OK I have volt meter and test light
May 25, 2007 at 2:28 PM
MATT41178
  • 31 POSTS
I cant get the car to start I have jumped it and it started but now it wont do that any more and one more thing I didnt mention is the switch on the clutch peadal keeps coming off it will go back on but it still wont start also i think i have something draining the battery the voltage on both the batt and using the block are at 9.8 volts I a charging the battery right now.
May 25, 2007 at 5:37 PM
MATT41178
  • 31 POSTS
#10 fuse is good all fuses have been checked and voltage on the charger is 12.45.
May 25, 2007 at 5:55 PM
MATT41178
  • 31 POSTS
Hello
Ok I have charged the battery and voltage on battery not connected to the car was 14.00 and connected to the car voltage was 13.18 on both terminals and off block, and the car still wont start,
I have the battery disconnected because it seems like something is draining it fast.
May 26, 2007 at 11:03 AM
MATT41178
  • 31 POSTS
No no arc but I can hear the fuel pump come on,
and Ijust tried to push start it and it wont start.
May 26, 2007 at 11:32 AM
MATT41178
  • 31 POSTS
The fuel pump stops after a few seconds and there is no aftermarket anti theft it does have the factory one with the red light above the hazard button
May 26, 2007 at 11:43 AM
MATT41178
  • 31 POSTS
Yes I have two keys one in it bilnks rapid with the other it doesnt
May 26, 2007 at 11:49 AM
MATT41178
  • 31 POSTS
tested again and both keys light is rapid now
May 26, 2007 at 11:54 AM
MATT41178
  • 31 POSTS
Ok i put both keys in glove box and tried to start but now the light does nothing no bilinking with both keys. and still wont start
May 26, 2007 at 12:08 PM
MATT41178
  • 31 POSTS
does not blink every 4sec and does not turn over tyring key 2 now
May 26, 2007 at 12:24 PM
MATT41178
  • 31 POSTS
Now I have tried both keys and have no blinking light at all and eng wont turn over or even cilck and didnt before.
May 26, 2007 at 12:33 PM
MATT41178
  • 31 POSTS
both are the same 12.93 and bettery is dicherging as it is connected to the car with key off
May 26, 2007 at 12:55 PM
MATT41178
  • 31 POSTS
the pos battery cable was getting hot the first time I got it running and it is burnt on the side of the battery but I cant get the whole harness off with out taking off the starter.
May 26, 2007 at 1:38 PM
MATT41178
  • 31 POSTS
ok I just jumped the cluthch switch and still no start or any thing
May 26, 2007 at 1:45 PM
MATT41178
  • 31 POSTS
what do you mean get them apart I got them so they arent touching but they werent wire to wire, did you mean disconnect them. tested to make sure all fuses have power going through them all was ok but still no start and voltage now down to 12.65
May 26, 2007 at 2:39 PM
MATT41178
  • 31 POSTS
now you got the car to turn over jumping the nuetral switch but will not fire up.
May 26, 2007 at 4:31 PM
MATT41178
  • 31 POSTS
ok Ijust checked all fuses and when it wouldnt start i changed the fuel pump relay and it is now running with alt cable dissconn
May 26, 2007 at 5:12 PM
MATT41178
  • 31 POSTS
voltage on batt ang off eng bolck are both at 12.45
May 26, 2007 at 5:14 PM
MATT41178
  • 31 POSTS
reconn alt and now checked voltage and is 15.10 on batt and 15.10 on block
May 26, 2007 at 5:22 PM
MATT41178
  • 31 POSTS
what wire do i connetct to batt brom alt
May 26, 2007 at 5:39 PM
MATT41178
  • 31 POSTS
no light when toching the alt pst but if it toches alt body Ihave light
May 26, 2007 at 6:00 PM
MATT41178
  • 31 POSTS
what and where is the PCM and i checked the alt and get no light whene conn to the alt red wire to alt terninal for the red wire so would this mean its the regulator
May 26, 2007 at 6:06 PM
MATT41178
  • 31 POSTS
Iam little confused on what post you want me to conn the clamp to and what to touch with the other end of the test light.
May 27, 2007 at 1:28 PM
MATT41178
  • 31 POSTS
Ok I just srarted the car again and voltage on the batt while running is 14.5
May 27, 2007 at 3:14 PM
MATT41178
  • 31 POSTS
the test light comes for about 1 second, and alt light in the dash is still on.
May 27, 2007 at 3:57 PM
MATT41178
  • 31 POSTS
yes please.
May 27, 2007 at 4:08 PM
MATT41178
  • 31 POSTS
fuse 50 7.5 is good.
May 27, 2007 at 5:00 PM
MATT41178
  • 31 POSTS
I dont mind the light but I am going to trade this thing in next week for a larger car (I have 4 kids) and dont want any fuss about it.
As for the clutch switch whene I jump the two wires on the switch it wont start, I have to ground one of them to start it so it doesnt seem like its the switch.
May 27, 2007 at 5:15 PM
MATT41178
  • 31 POSTS
thanks for all your help.
I also have 1992 formustang that wont get power to fuel pump?
all relays have been changed and fuses checked.
May 27, 2007 at 5:27 PM
