2006 Ford Fiesta ELECTRIC WINDOW MOTOR
2006 FORD FIESTA
LEZBEZ
Electrical problem
2006 Ford Fiesta Two Wheel Drive Manual
FOLLOWED CAR MANUAL TO REMOVE DOOR PANEL BUT WINDOW STUCK HALF UP SO CANT DISCONNECT GLASS TO REMOVE INNER PANEL TO GET AT WINDOW REGULATOR BUT MOTOR TORQUE SCREWS ARE VISABLE---ANY SUGGESTIONS HOW TO PROCEED PLEASE?--WINDOW DOES MOVE A FEW CENTIMETRES UP AND DOWN
Aug 19, 2010 at 5:46 AM
SATURNTECH9
  • 30,869 POSTS
Try taping on the window motor with a hammer while moving the window switch.If that doesn't move the window where you need it then you can try unbolting the window regulator just make sure you hold the window so the regulator and window doesn't come crashing down.Then you should be able to unhook the window.
Aug 19, 2010 at 5:17 PM
