2001 Ford Fiesta Washer bottle
2001 FORD FIESTA
49,000 MILES • 4 CYL • FWD • MANUAL
MATT63
How do I replace the entire washer bottle - current bottle cracked and leaking.
Dec 6, 2008 at 5:36 AM
DAVE H
  • 13,384 POSTS
the fiesta was never relaeased in the U.S. so i do not have any diagrams for you but it's a simple job to do ..
Remove washer reservoir bolts. Remove washer reservoir by pulling straight up.
Disconnect washer pump connector and hose. Drain washer solvent into clean container.
Pry washer pump from washer reservoir. Remove washer pump to reservoir seal and discard if there is any sign of wear. To install, reverse removal procedure. Tighten nuts and bolts to specification.
Dec 6, 2008 at 5:52 AM
