Turn the key to try to start the car, and you may get nothing for a couple of seconds, but then the starter will begin to turn slwly, eventually getting up enough speed to crank the engine. Drive the car up to operating temperature, kill it, and the starter may crank the engine right back and it may do the same as before. Intermittent problem. FYI - The ignition switch is worn and the key will come out while the switch is on. Thought this could be related.
Dec 7, 2008 at 9:07 PM
