FORD festiva 1993 185000 mi.
1993 FORD FESTIVA
J.WALKER
when the headlight switch is turned on the lights don't come on & there's a clicking sound coming from the headlight relays behind the radiator reservior. i replaced relays with salvage yard peices but it didn't solve the problem.any suggestions would help. thanks JW
Nov 30, 2007 at 6:42 AM
2CARPRO JACK
  • 11,533 POSTS
Sounds like a bad ground or low voltage issue at the relays. Test for 12 volts and good ground where the relay plugs in
Nov 30, 2007 at 12:14 PM
