1993 Ford Festiva Torque converter control module
1993 FORD FESTIVA
230,000 MILES • 4 CYL • FWD • AUTOMATIC
HOWARDJR
Where is the torque converter control module located on a 1993 festiva.
Aug 15, 2010 at 12:18 AM
You must be talking about the TCC solenoid its contained within the valvebody of the transmission
Aug 15, 2010 at 2:15 AM
HOWARDJR
rasmataz, thanks for you help. I have a couple more questions for you. Is it hard to change and does it require taking the transmission out?
Aug 15, 2010 at 11:36 AM
Never done it with this vehicle-if you can remove the transmission fluid pan w/o removing the tranny go for it -you see the the valve body when you remove the pan.
Aug 15, 2010 at 5:05 PM
