1993 Ford Festiva intermitten
1993 FORD FESTIVA
13,000 MILES • 4 CYL • FWD • MANUAL
LABRAT45
the car sometimes runs fine and other times it cuts out and loses power.sitting still idling it does not appear to have a problem then at times it starts fluttering and acting up when i drive it and floor it,it stops running when i back off the throttle it runs again it's really bad when i put a load on the engine,here is what i have done also sometimes when i start it at times i have to pump it a couple of times but most of the time idling its very smooth
Rotor cap and wires plugs
removed gas tank and cleaned fuel pump pumping good
changed coil
checked wire ends looked for air leak none
getting good spark
check to see if it jumped a tooth on the timing it did not
checked timing good
replaced catalytic converter
cleared out fuel lines and injector rack
replaced o rings on injectors
cleaned engine plug connectors
when this car runs at top end 40 to 50 mph it jerks and surges real bad and misses and sometimes idling i can hear the injectors picking up and slowing a minor surge you might say is this the computer ? does the injectors run on a inline fuse ? what it acts like is the timing and injectors are not progressing with the R.P.Ms could the computer codes be out of sinc ?
Jul 27, 2008 at 11:52 AM
MY68MONTERAY
  • 17 POSTS
good possiblity its the fuel pump, it sounds funny but my festiva was acting up like that, expecialy when i got on it to go up hill, and when the motor got up to running temp. try to find a used one cuz a new one cost me $175 and it wasn't even the whole sending unit/pump. it was just the motor. it will be different if it's manual shift, then you will have a manual/enertia fule pump. i had an automatic and they have motorized fule pumps
Nov 22, 2008 at 9:42 PM
