I am trying to remove the CV joint from the axle while the inner part of the axle is still sitting in the gearbox.
Is there a way to remove the CV from the axle without removing the whole axle?
It seems to be held in with a clip of some sort, but I cannot see one! There is about 1mm of play on the shaft with the CV.
Or how do I remove the whole axle if this is the only way?
Thanks!
Thanks!
Mar 30, 2008 at 1:35 AM
