1992 Ford Festiva Horn doesn't work
1992 FORD FESTIVA
35,000 MILES • 4 CYL • FWD • MANUAL
LANI GEORGE
I wanted to check the connections to the horn but cannot find it under the hood. Can someone tell me where to look?
Sep 1, 2010 at 9:35 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Your horn will be located below the passenger side headlamp mounting bracket. It has a green/red wire running to it. If the wiring is good than check the horn relay (behind left side of the instrument panel) and also fuse labeled STOP (15 amp). If all of this is good than either the horn switch on steering wheel is bad or the horn itself is bad.
Oct 22, 2010 at 12:18 AM
