1991 Ford Festiva Horn will not sound
1991 FORD FESTIVA
ALSCRIBE
Electrical problem
1991 Ford Festiva 4 cyl Two Wheel Drive Manual
Since the brakelights work, the fuse for them and the horn is presumably OK.
I guess there's a loose wire or connection but I can't see where the horn itself is nor which wires go to it.
I'd welcome your suggestions.
Thanks
Alscribe
May 7, 2008 at 2:10 PM
SCOTTXD45
  • 26 POSTS
Whe you press the horn switch do you hear a clicking noise? If not check the horn relay. Other than that just check the voltage at the horn with the switch pressed.
Jun 13, 2008 at 12:05 AM
