[quote:27dbe08395="mhpautos"]Hi there,
Thank you for the donation,
i agree, that charge rate is to high, i would start with getting the alternator bench tested and also check that the earths and battery terminals are clean and tight, start here.
mark (mhpautos)[/quote:27dbe08395]
i changed out the Pos. terminal connector on the battery and cleaned up the wires. I'm now getting a charge of 14.7vdc,this is probably normal.Can i assume that the fusible link will still stay hot to the touch when things are operating normally?
Apr 9, 2009 at 9:46 AM
