Hi there ! I'm a refrigerant licence (but NOT car air cond ) .I bought 1 R134a bottle 12 kg and I service my car air cond today .I check LOW side pressure : still got Refrigerant in system and about 40PSI when air cond is ON (like normal ) ,but the air blow out temperature is 14 degree celsius(not cold down anymore ) , I took al old gas out to a reclaim cylinder with my recovery machine ,then changed another compressor (but not change a dryer ) ,vacuum pump it , and regas with a new R134A to 40 PSI again ,check system and the air blow out temperature is 14 degree celsius(not cold down anymore ) ,just like before . The compressor is on continually (not ON-OFF ), 2 hoses is cold ,wet and drain water drip out to the concrete floor from inside ;everything look normal ,but the temperature is 14 degree celsius only ,NOT strong cold . I regas another Ford ( same model-it's my Dad's car ) and air blow out can come to 6 degree celsius ... Please help me some thingon my car... Thanks a lot .Regards !
Dec 8, 2008 at 5:21 AM
