1995 Ford Falcon On OIL Ok! On GAS car car shake
1995 FORD FALCON
223,100 MILES • 6 CYL • 2WD • AUTOMATIC
U3002083
when i run the car on Petrol car runs ok. but when i switch to LPG car starting to shake. But if if i accelerate little it seems ok. what is causing this problem. it mean that engine is not getting much LPG. hope some one will solve this problem.
Dec 23, 2009 at 3:57 PM
MHPAUTOS
  • 31,937 POSTS
Hi there, this will be a gas mixture problem, depending on the system you have and the age of it, some converters are adjustable and others are controlled by a ECU, you will have to get a gas accredited tech to check and adjust this for you.
mark (mhpautos)
Dec 23, 2009 at 5:04 PM
