1994 Ford Falcon wont turn over
1994 FORD FALCON
TERIKC
Engine Mechanical problem
1994 Ford Falcon 4 cyl Front Wheel Drive Automatic
The other day i tried to connect a new head deck i cut the wires form the plugs and connected the wires to the head deck i got the head deck going there was a small spark i went to start the car and it will ignite but just not turn over. A friend had a look at it and suggested it could be the fuel pump we replced that but my car still does the same thing HELP[img:b3a811f22e]http://www.2carpros.com/forum/automotive_pictures/403959_2_1.jpg[/img:b3a811f22e]
Sep 1, 2009 at 6:20 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
start with checking all the fuses as you may have blown one, you may have to get a scan done to check for any unresolved fault codes, also check that the interior light is still working as this circuit is tied in with smart lock and if the fuse or globe is blown this can cause some strange problems as well.
mark (mhpautos)
Sep 1, 2009 at 6:26 PM
TERIKC
[quote:b2441390a8="mhpautos"]Hi there,
mark (mhpautos)[/quote:b2441390a8]
HIya mark blown a 30amp fuse in the inside fuse box and have since replaced it the interior lights on the dash are working but the inetrior lights in the car on the roof arent neither are the windows have checked the fuses are all ok how do i get scan done
Sep 1, 2009 at 6:52 PM
MHPAUTOS
  • 31,937 POSTS
Every mechanic should have a scanner, there is a conection in the fuse panel, they just plug it in and it will read any fault codes.
Mark
Sep 1, 2009 at 9:29 PM
