Electrical problem
1994 Ford Falcon 6 cyl Two Wheel Drive Automatic
we have tested the fuses by disconecting the negative terminal of battery using a multi meter and pulling fuses one by one, the crt lp was the only one that seemed to be pulling amps. All were at 12.35 except this one reduced it to 12.03.
No lights are on in the car, boot interior glove box.
battery is drained when car is not in use.
but if you disconnect battery it will start again.
Jul 25, 2010 at 8:03 PM
