1990 Ford Falcon My interior fan does not work!!!
1990 FORD FALCON
200,000 MILES • 6 CYL • 2WD • AUTOMATIC
LITTLECHOPS2006
  • 6 POSTS
I own a ford falcon EA model, My interior fan is causing me problems,
we live on a property with four cattle grids, and when we drive the car the fan would not work then when we drove over the cattle grids the fan would start, that happenned for awhile, though now the fan does not work at all! We have narrowed it down to a loose wire or something! all fuses are ok,
So my question is where is the fan located and what ealse can you advise me on the check?
Nov 28, 2008 at 8:15 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
These fans are a real pain, the fan is located in the heater box, to access this the glove box and surround must be removed and the black air box at the far left removed its all a bit tricky but its explained in the work shop manual ( there are no Aussie pics on this site) if you don't have a manual i may be able to send you something i can scan and Email from work, ( i live in Vic where are you?) the fan will more than likely be stuffed, as this is often the case, if you cant get a manual let me know.
Mark (mhpautos)
Nov 28, 2008 at 8:28 PM
LITTLECHOPS2006
  • 6 POSTS
Hi
Thank you for your
much needed advise, if you could send me pictures that would be great, I have located the fan now though I m still unsure what wires go where and so and so! Its is quiet frustrating.
My email address is the following:
[email protected]
That would be a great help! I have not got a manual currently, though the amount of trouble I m having with my car I m sure I m going to get one ASAP!
[quote:8628e32f87="mhpautos"]Hi there,
Mark (mhpautos)[/quote:8628e32f87]
Dec 11, 2008 at 5:44 AM
