1989 Ford Falcon Replace fuel pump
1989 FORD FALCON
240,000 MILES • 6 CYL • 2WD • AUTOMATIC
  • 4 POSTS
I have a six 6 cylinder ford falcon sedan
How do I replace fuel pump?
Regards
George
Dec 10, 2009 at 5:35 PM
MHPAUTOS
  • 31,937 POSTS
HI there, for the EA Falcon Sedan, remove boot mat, there is an access panel L/top side, remove and there is the pump access point , undo hoses and electrical plug, there is often a large clamp around the locking ring, remove this, the locking ring is plastic and it can be tight, there is a special tool to remove this if required, with ring removed pump & sender will lift out, pump unit then can be replaced, also fit a new fuel filter and you will need to get a new sender unit seal from your dealer as your old one may not fit back due to swelling.
Mark (mhpautos)
Dec 10, 2009 at 5:46 PM
