1987 Ford Falcon stopped working
1987 FORD FALCON
300,000 MILES • 6 CYL • 2WD • MANUAL
WHAKACHEF
hi my car just stopped working was driving then stopped engine rotates but not start checked coil its ok no spark getting through but volts are fine think it may be computer what do you think
Jun 6, 2010 at 10:00 PM
Cranks over and will not start do below
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Jun 6, 2010 at 11:50 PM
