1964 Ford Falcon master cylinder
1964 FORD FALCON
ROUSH2WIN
Brakes problem
1964 Ford Falcon V8 Two Wheel Drive Automatic
Will a 68 mustang duel master cylinder work on a 64 ford falcon, If not what duel master cylinder will work on a 64 falcon.
thanks
Nov 1, 2009 at 6:26 PM
HMAC300
  • 48,601 POSTS
the 68 master might work, but you just can't put a dual master on a single system. Besides having to reroute lines, you 'll also have to install a proportioning valve. You would also need to know if the rear wheel cylinders were the correct size for the master to operate them correctly. I think you would be better off looking into an aftermarket system such as wildwood or baer...
Dec 23, 2009 at 11:53 AM
