Hi there,
There is not much you can do regards servicing these transmissions, only change the oil & filter. Take the pan off and check for any metal in the bottom, if the oil is really dirty the filter may be blocked and restricting oil flow, apart from that it would be an idea to have a fault code read done, that may give you some idea as to what you are up for.
Mark (mhpautos)
Nov 8, 2007 at 2:35 AM
