ford falon 95
1995 FORD FAIRMONT
ANGRY147
auto works fine when cold.when warmed slips & bangs through gears upshifting
Nov 7, 2007 at 6:12 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
There is not much you can do regards servicing these transmissions, only change the oil & filter. Take the pan off and check for any metal in the bottom, if the oil is really dirty the filter may be blocked and restricting oil flow, apart from that it would be an idea to have a fault code read done, that may give you some idea as to what you are up for.
Mark (mhpautos)
Nov 8, 2007 at 2:35 AM
