1981 Ford Fairmont battery wont hold charge
1981 FORD FAIRMONT
71,900 MILES • 6 CYL • 2WD • AUTOMATIC
MIXXER
i replaced the alternator- starter- voltage regulator - new battery starter solinoid. but after i drive it a day or two and when the lights are on i shut it off and battery is dead again thanks dave
Dec 26, 2008 at 9:21 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
Go back and start the checks from the beginning, make sure that the charge rate is between 13V & 14.5 V check the terminals are clean and tight, load test the battery for a faulty cell, and if that is all ok, have a current draw test done, this will show any circuit that is drawing battery current when it should not, start here.
mark (mhpautos)
Dec 27, 2008 at 6:06 AM
