2000 Ford F-650 Takes longer to start than it should
2000 FORD F-650
13,555 MILES • 6 CYL • 2WD • AUTOMATIC
LUERAMA
Most of the time I get in my truck it takes longer to start than it should. The starter is cranking engine too long before starting. Sometimes followed by a bogging sound that immediatly gose away. I am afraid I am going to ware out the starter. It dose not mater if the truck is cold are hot. This has been happening for years. It drives well once its running. Everytime I replace spark plugs they are dry and tan. My check engine light came on and checked codes. I replaced MAS and Oxy sensers, Air filter, Spark plugs, Plug wires, had injectors cleaned. I do not here any vacumb leak. Should I spend the money on an engine dionostic? I have not worked in 9 months.
Apr 15, 2010 at 2:33 PM
Hi luerama, Welcome to 2carpros and TY for the donation
Let's start by checking the fuel pressure if its within specs if okay test the coolant temperaturre sensor and fuel pump relay
Apr 15, 2010 at 4:50 PM
