1995 Ford F-450 no power at power
1995 FORD F-450
214,000 MILES • V8 • 2WD • AUTOMATIC
PARIS1763
sometimes we give it gas and it has no power,, but then we can punch it and it takes off,,,at times we hear a popping sound while driving down the road, it does it once in a while. other than that the truck doesnt have any problems engine does not smoke. please let me know if you have heard of anything like this before
Jun 25, 2010 at 6:32 PM
Possibilities: Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard
Jun 25, 2010 at 9:54 PM
