Starter solenoid replacement
FORD F-350
KAREND
Is it possible to replace a starter solenoid in my 2002 E-350, v10, 6.8L van?
Or will the whole starter have to be replaced?
~karen
May 18, 2007 at 11:41 AM
RUDPRO
  • 224 POSTS
The solenoid is mounted on the starter. You'll have to take it to a shop that repairs starters, look in the yellow pages, they should be able to replace the solenoid. Othewise, you'll have to replace the whole starter.
May 18, 2007 at 1:00 PM
KAREND
[quote:4413665c67="justanold"]HELLO! Describe what your symptoms are in detail before you remove starter please. 8) 8) 8)[/quote:4413665c67]
The ignition "clicks" but doesn't turn over. This usually happens if I've worked the engine a little hard, turn off the van, then go to start it up - while it's still hot? There is lots of power so it's not the battery. And usually if I wait a couple of hours it'll start.
May 22, 2007 at 8:02 AM
MARIO ANDRETTI
can anyone give me the wiring diagram for the starter solenoid in an E -350 ford V-10 van /
Jun 29, 2016 at 6:47 PM
