2002 Ford F350 Dually--manual 6 speed-- 108000miles-- 4wd--
Had severe brake pull to the right when applying brakes. Found right pads ground to nothing. Replaced both front rotors, caliper assemblies including mounting brackets and both brake lines. Less than 500 miles, pull started again. Replaced complete left caliper assembly. Short time later again a pull to right. Replaced complete right caliper assembly. Within 50 miles, it was pulling again. The pull is severe enough that if I don't hang on to the steering wheel, it spins hard to the right. A severe stop almost put me in the ditch.
Tires are equally inflated.
I am at a loss for what is causing this.
May 14, 2007 at 7:51 AM
