My name is dave
I have a 6.4 liter diesel that i need help with.
Here is the problem:
When i run my truck and shut it off or just turn key on and then back off the power keeps feeding the turbo charger actuator, egr valve actuator, and egr throttle plate valve. Only way to shut it off is to disconnect the battery cables and they stay off until key is turned on again. Unplugging individually and plugging them back in they still hum and have power to them.When scanning i got code p132b turbo charger boost control A performer. Did test and it tested ok. Code p1335 egr valve plate postion sensor min performer tested ok. Code p042e egr actuator stuck open. I replaced it with a new one but hte problem is still there. Also replaced pcm. Problem is still there. I need help
My name is dave
Oct 11, 2009 at 10:40 AM
