2008 Ford F-350 head torque
2008 FORD F-350
261,000 MILES • V8 • 4WD • AUTOMATIC
MIKE N DEB
hello lifter came apart had to replace removed heads inline unable to locate proper torque down on head bolts could you offer any help and thank you for offering a site like this mike n deb mide holler f350 6.4 super duty 4wheel drive diesel 2008
Oct 17, 2010 at 1:11 PM
TECH1FORD
  • 102 POSTS
with the 10 big head bolts you tighten inside out so the middle one on the top is number one. so tighen that one, then the one below it, then the one to the right of it, then to the one one an angle to the left, then the one below that, then accros the head top right then the one below that, then croos the head top left, then the one below that. so first step tighten all to 0 to 70 ftlbs. second step lossen them off, third step tighten to 115ftlbs, fourth tighten is sequence 90 degrees, fifth step a second set of 90 degrees. sixth step tighten the top 5 little bolts to 18ftlbs inside out again, then last to 23 ftlbs. hope this makes sense and good luck
Oct 25, 2010 at 7:28 PM
