2007 Ford F350 DTC # P0284
2007 FORD F-350
47,000 MILES • V8 • 4WD • AUTOMATIC
JWMIII
My truck has the DTC # P0284 it runs very ruff at first startup of the day and is fine after it warms up. The code is cylinder contribution / balance, what needs to be repaired, should it be covered under the warranty, is it an easy fix for the shade tree mech?
Nov 22, 2009 at 1:15 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
Thank you for the donation,
I would first confirm if this is a warranty issue for your dealer to take care off, if so go that way, if not, this code is for what you reported but i get it as in No8 cyl. so i would be checking out, injector, vacuum leaks and ignition on that cylinder.
Mark (mhpautos)
Nov 22, 2009 at 6:33 PM
