Do you need to remove the engine to replace the front engine seal?
May 27, 2009 at 5:00 PM
2CARPRO JACK
CERTIFIED EXPERT
No, bu tyou will need to remove the fan and fan shroud, most likely the radiator.You will also need some kind of an impact gun to get the front crank bolt out, then a puller to remove the crank pulley
