Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Ford
F-350
Engine
Camshaft
Replace/Remove
2004 Ford F350 Cam positioning module
2004 FORD F-350
DONNYJ
MEMBER
FOLLOW
2004 Ford F350
Where is the cam positioning module and how do i change it out
Jan 8, 2010 at 2:57 AM
CERTIFIED EXPERT
2004 Ford Truck F 350 4WD Super Duty V8-5.4L SOHC VIN L CAMSHAFT POSITION (CMP) SENSOR REMOVAL 1.Disconnect the battery ground cable.
2.Disconnect the camshaft position (CMP) sensor electrical connector.
3.Remove the bolt and remove the CMP sensor. INSTALLATION 1.To install, reverse the removal procedure.
Jan 8, 2010 at 3:32 AM
