2002 Ford F350 Door indicator light will not go off
2002 FORD F-350
160,000 MILES • V8 • 2WD • AUTOMATIC
JJAMES011958
Can someone tell me what causing the problem with my door indicator light, it will not go off. It continue to buze all the time.
Dec 20, 2008 at 4:17 PM
DAVE H
  • 13,384 POSTS
check the switch and wiring to the switch on the door pillar near where the hinges are located on drivers/passenger doors ?
Dec 20, 2008 at 4:50 PM
1MGCMN
[quote:ed7ec622c6="jjames011958"]Electrical problem
2002 Ford F350 V8 Two Wheel Drive Automatic 160000 miles
Can someone tell me what causing the problem with my door indicator light, it will not go off. It continue to buze all the time.[/quote:ed7ec622c6]
Try unloading a can of WD-40 in the latch on the door. There are pin switches in these latches that get sticky. It may be necessary to remove the inner door panel to gain better access. This is a very common problem w/ fords.
Greg
Dec 21, 2008 at 5:54 AM
