2002 Ford F350
2002 FORD F-350
171,000 MILES • V8 • 4WD • AUTOMATIC
MSAUCIER1
After I start the truck and press on the brake pedal to shift out of Park, it does not shift. I have to shut off the engine, turn key to 1st click, shift transmidsion into neutral, then start the truck. Why is the brake pedal not talking to the trnasmission? and how do I fix it?
Jun 22, 2010 at 12:50 PM
BLACKOP555
  • 10,386 POSTS
brake lights work? and if its collumn shift the brake switch doesnt talk to the computer. the lock is in the ignition switch which is why turning it to the first click works.
Jun 23, 2010 at 11:35 AM
BADGERFAN
i had this same problem on a 2003 F250. off the front of your brake fluid reservoir there is an electrical switch that is activated when you press the brake pedal. The o ring breaks down and begins to leak. This shorts out the switch. Your truck should be covered under a recall for this problem. This problem is what what causing fires under the hoods.
Jun 23, 2010 at 3:40 PM
