2001 Ford F350 Instrument panel / O.D. off / 4WD switch not
2001 FORD F-350
90,000 MILES • V12 • 4WD • AUTOMATIC
DDAAPP
The instrument panel / O.D. button / 4W.D. switch stopped working during some off road work. Driving thru some tall grass on a farm all the gauges, ect. stopped working. The odometer also does not work.
I crawled under the truck to look for obvious damage and found none. The battery and seat belt symbols still work on the display panel when starting the engine.
Jun 1, 2010 at 11:54 AM
MERLIN2021
  • 17,250 POSTS
If it all worked before the four wheel drive thru tall grass, check the ground wire behind the left front fender. Does the truck run? And is it a 6.8 or a diesel?
Jun 4, 2010 at 7:06 PM
DDAAPP
Everything worked before going thru the tall grass. I tried to use the 4 wheel drive by locking in at the hubs but this didn't work either. I checked the ground wire loosened retighten with no change. This is a 6.8L engine and yes the truck runs. I've been driving it around. Also the cruise control works but the indicator on the instrument panel does not light up.
Jun 11, 2010 at 4:08 PM
