2001 Ford F350 Ball joints
2001 FORD F-350
90,300 MILES • V12 • 2WD • AUTOMATIC
SCOTTCMASS
When do you determin if they need to be replaced?
Oct 12, 2008 at 9:36 AM
BLACKOP555
  • 10,386 POSTS
check the wear surface, if its recessed it needs replacmeent, check with the ball joints loaded.
with the ball joints unloaded wiggle the tire and check for movement in the ball joints, if movement is noted they need replacment.
also if the boots are torn.
or 100000 miles comes around and they havent been replaced they need replacement.
Oct 12, 2008 at 11:23 AM
